After upgrade Techs can no longer run any scripts
when they import the shared scripts these are duplicated in their Toolbox
also when selecting the scripts from import they go white (colour is incorrect) you scan still scroll down as they disappear due to colour - then click import
Note: when searching for the script there are TWO both work (one under imported one under toolbox)
