One of my clients has a Windows XP embedded “server/workstation” that has been sat at “restart required” for quite a few versions.
They don’t want replace the hardware, or upgrade the software, but how can I connect to the system without it waiting for the remote computer to be updated?
Server is currently running v5.2.9 (intent to update to v5.2.11 imminently - but doubt that would change the connection ability)
I don’t believe “Resstart Required” means you need to restart the COMPUTER. It just means the simple-help service needs to be restarted. You can do that from the technician console. Select the computer, pick the “Advanced Options and Controls (gear)”, and click “Auto-restart.” Then wait for a few minutes. That will cause the service to restart, and then the message you are seeing should go away and you should be able to connect.
I was aware it was service rather than system that needed to be restarted.
Service version reports a 5.2.7, and it won’t restart the service to update to 5.2.9 and because of that; initiating a remote connection just shows “The remote computer is updating…”
System has been rebooted, thus restarting the service, but still refuses to connect.
Sorry, I misunderstood.
I have NOT experienced the problem you are seeing. You might want to open a ticket with Simple-Help to see if they can offer an answer that would be useful.
Sounds like the service is broken. I’ve had that on a few slower machines or ones with flakey network connections. You usually need to stop it, remove it, clean out the supporting files and reinstall the RA service.
