I’ve got another report of weak ciphers from my Nessus scanner on the Mobile VNC/SSH port. Specifically.
The following weak server-to-client encryption algorithms are supported :
arcfour128
arcfour256
The following weak client-to-server encryption algorithms are supported :
arcfour128
arcfour256
Anyone have ideas on how to disable these weak encryption algorithms? I don’t see any options in the ./configuration/ folder for this.
