Exclusion Path for Antivirus
Bitdefender seems to be blocking SH on some occassions. What is the exclusion path? Does each release have a new directory? This looks like it.
C:\ProgramData\JWrapper-Remote Access\JWrapper-Windows64JRE-00063527423-complete\bin\remote access.exe
Or is it always 00635…?
Do you mean windows bitdefender?
Windows Firewall?
Or Bitdefender GravityZone AV?
It does change. Your best bet is to allow the folder: C:\ProgramData\JWrapper-Remote Access
You will also want to allow “C:\ProgramData\SimpleHelp\ElevateSH\SimpleService.exe”
“C:\ProgramData\SimpleHelp\ElevateSH\elev_win.exe”
We use bitdefender gravity zone on about 500 endpoints (all of which have simple-help) and have not had an issue of anything blocking SH.
I am curious what version of BD and SH you are using.
