Good morning,
I would like to learn more about SimpleHelp commands.
I need to create a tool that allows me to send a video, stored on my PC, to multiple devices at a specific address.
Good morning,
The run command is just for whatever your OS cli commands are.
For example windows its cmd commands.
If your just placing a file leave the command to run blank.
Put the file in resources like you have.
The working directory is where the file will be placed and the starting directory of the cli.
Running the toolbox with the command line empty will just copy the file to the working directory.
See the guide here:
https://simple-help.com/toolbox-guide.html#creating-a-tool
