Hello,
I have been looking for a way to integrate a software key finder into simple-help. It would make our job easier when having to remote reinstall software for a user.
Does anyone have an idea the best way to do this?
Thanks all!
Hello,
Thanks all!
Hi,
my solution is GLPI and plugin FusionInventory. All open source and free.
I would also love and willing to PAY for a software license audit solution in SH. I currently use a separate 3rd party tool but would like it integrated into SH. I don’t want a separate solution like GLPI. Thanks!
Hi all.
To do this I have created a tool in the toolbox that uses nirsofts keyfinder. produkey v1.93
made a batch script:
@echo off
produkey.exe /stext produ.txt
type produ.txt
Hopefully this helps someone else get the products keys from windows machines with simplehelp toolbox.
Thanks Darrell! Will give it a try.
Anyway to import the produ.txt into the notes for that machine?
In the 5.2 beta this should be possible
We are in 5.2. Any ideas?
I do not know of a way to add it to the notes automatically.
You could use the scripting api to email the code to email of your choosing, or write it to a log file on the server, or to the machine property.
https://simple-help.com/toolbox-guide#Scripting-API-Functions
I love the idea of a toolbox for running a software key retreival tool! My plan was to have it dump the output to my private SFTP server. However, Windows Defender flags ProduKey.exe as malicious when I went to test it.
Hi David, what if at the beginning of the script you set an exclusion in Defender…
