There’s a ton of info about Windows client deployment. It seems that there is an expectation that the documentation should transpose to macOS and Linux. It does not.
For example on macOS, I cannot find a list of the required TCC permissions for the app.
These are standard for every other Screen Sharing …
Screen Recording
Full Disk Access
Accessability
But it also looks as though it needs to be granted
Automation->System Events.app
None of this is difficult to push out (except the impossibility of deploying an Allow PPPC for Screen Recording), but I’m really not seeing this documented anywhere. Am I missing something?
Also on Linux, I just have no idea how to deploy. I’m able to do the “mass deployment” and that works, but I’m at a loss for anything else. I’d hoped that the “Mass Deployment” would give detailed feedback/logging but I’m not finding it.
Are Linux and macOS deployments detailed somewhere?
Cheers.Peet
