Hello,
I am looking at deploying BGinfo or something like that to a mass deployment to a lot of small businesses unrelated to eachother. So using AD is not really an option.
Any ideas?
Thanks all!
Hello,
Any ideas?
Thanks all!
Hi @Josh_Barrett, you would do this by creating a Toolbox. BGInfo is small, so you could likely add this as a resource and this would take care of “sending” BGInfo to the machine you run the toolbox on.
You would then Run a command or Run a script depending on what you want to do with the resource.
Documention on Toolboxes can be found here.
There are lots of Toolboxes available in this thread and importing these should give you a fair idea how they work and you can then develop your own.
Thank you! That worked!
