Need Help Automating Import feature
Here is my code. It will work when I create it as a toolbox and run it manually but If I automate it to run then it doesn’t work.
FOR /F “tokens=* delims=” %%x in (c:\temp\scancircle.txt) DO echo ServerUtilsSetMachineProperty(@ThisMachine(),Computer Data,%%x)
if its run from the Toolbox and it works probably, Toolbox gets admin access, if its a script you don’t get admin once the toolbox is closed
Try changing your quotes from
“tokens=* delims=”
to
“tokens=* delims=”
hmm. or is that just the editor formatting the quotes? I cant tell now.
Simple Help had a bug. They fixed in in the newest release. The quotes get messed up on this forum, make sure they are ascii quotes.
