We used some cloned images a while back and ended up with multiple computer names in SH showing the same name. So I wrote a toolbox powershell script to set the computer names back to there hostnames without losing the groups there in. Enjoy
$filePath = "C:\ProgramData\JWrapper-Remote Access\JWAppsSharedConfig\serviceconfig.xml"
$replacementText = "AUTODETECT"
# Check if the file exists
if (Test-Path $filePath) {
try {
# Load the XML content from the file
[xml]$xml = Get-Content $filePath
# Select all <Name> elements
$nameElements = $xml.SelectNodes('//Name')
# Iterate through the <Name> elements
foreach ($nameElement in $nameElements) {
$text = $nameElement.InnerText
$lastSlashIndex = $text.LastIndexOf('/')
if ($lastSlashIndex -ge 0) {
# Replace the text after the last forward slash with AUTODETECT
$nameElement.InnerText = $text.Substring(0, $lastSlashIndex) + "/$replacementText"
# Save the modified XML back to the file
$xml.Save($filePath)
Write-Host "Text after the last forward slash within <Name> tags replaced with 'AUTODETECT'."
} catch {
Write-Host "An error occurred while processing the XML: $_"
} else {
Write-Host "File not found: $filePath"
