I keep running into areas with crappy internet and I need to prep a client computer without disturbing them. So I made a script to download a file from a URL. Example: The client is busy. I cant take over the machine. I can’t download the file to my computer and then transfer it because of crappy internet. I need to download the large file directly to the client’s machine from a service provider, normally done via a browser.
The script asks the tech for the URL of the file then downloads it to the client machine under c:\temp\downloads.
Hopefully, this will help someone else as well. Maybe you can even improve it with a download bar or time remaining etc…hint hint.
##Refrence material:
##Split-Path (Microsoft.PowerShell.Management) - PowerShell | Microsoft Learn
##https://lazyadmin.nl/powershell/download-file-powershell/
##PowerShell - Create Directory If Not Exists - ShellGeek
##https://4sysops.com/archives/use-powershell-to-download-a-file-with-http-https-and-ftp/
#Set destination to download file too.
$destination = "c:\temp\downloads"
#Ask tech where to download from.
$source = “ServerUtilsAskTech (URL,text,http://test)”
#Check if destination exists. If not create it.
if (Test-Path $destination) {
Write-Host “Folder Exists”
else
#PowerShell Create directory if not exists
New-Item $destination -ItemType Directory
Write-Host “Folder Created successfully”
#get file name from download url
$destination = $destination + $(Split-Path -Path $source -Leaf)
#Invoke-WebRequest -Uri $source -OutFile $destination
Import-Module BitsTransfer
$Job = Start-BitsTransfer -Source $source -Destination $destination -Asynchronous -Priority normal -TransferType Download
echo “Running Job”
while (($Job.JobState -eq “Transferring”) -or ($Job.JobState -eq “Connecting”)) `
{ sleep 5;} # Poll for status, sleep for 5 seconds, or perform an action.
echo “completing job”
echo $Job
Switch($Job.JobState)
“Transferred” {Complete-BitsTransfer -BitsJob $Job}
“Error” {$Job | Format-List } # List the errors.
Seems like this would be very convenient indeed. I tried it and got the following error:
At C:\WINDOWS\TEMP\toolbox8036547725440715274run\Download20File-2-1647629459317-eudpw7gh.ps1:33 char:26
- while (($Job.JobState -eq �?oTransferring�??) -or ($Job.JobState -eq …
You must provide a value expression following the ‘-eq’ operator.
At C:\WINDOWS\TEMP\toolbox8036547725440715274run\Download20File-2-1647629459317-eudpw7gh.ps1:33 char:27
Unexpected token ‘�?oTransferring�??’ in expression or statement.
Missing closing ‘)’ in expression.
Missing closing ‘)’ after expression in ‘while’ statement.
At C:\WINDOWS\TEMP\toolbox8036547725440715274run\Download20File-2-1647629459317-eudpw7gh.ps1:33 char:45
Unexpected token ‘)’ in expression or statement.
At C:\WINDOWS\TEMP\toolbox8036547725440715274run\Download20File-2-1647629459317-eudpw7gh.ps1:33 char:69
- … ($Job.JobState -eq �?oTransferring�??) -or ($Job.JobState -eq �?oConn …
At C:\WINDOWS\TEMP\toolbox8036547725440715274run\Download20File-2-1647629459317-eudpw7gh.ps1:33 char:70
- … q �?oTransferring�??) -or ($Job.JobState -eq �?oConnecting�??)) { sle …
Unexpected token ‘�?oConnecting�??’ in expression or statement.
At C:\WINDOWS\TEMP\toolbox8036547725440715274run\Download20File-2-1647629459317-eudpw7gh.ps1:33 char:86
- … �?oTransferring�??) -or ($Job.JobState -eq �?oConnecting�??)) { slee …
At C:\WINDOWS\TEMP\toolbox8036547725440715274run\Download20File-2-1647629459317-eudpw7gh.ps1:33 char:87
- … �?oTransferring�??) -or ($Job.JobState -eq �?oConnecting�??)) { sleep …
+ CategoryInfo : ParserError: (
[], ParentContainsErrorRecordException
+ FullyQualifiedErrorId : ExpectedValueExpression
I think it’s just “smart curly quotes” instead of “boring straight quotes” issue - does this boring version work?
Yes, this works! I had to add a trailing slash after c:\temp\downloads but its working - this will be very handy. I was always connecting command line and using curl - but nw I will use this. Thank you for sharing!
ah,ya. Something probably got formated wierd when I copy and pasted it from my toolbox.
Glad you got it worked out.
