Has anyone already installed 5.5.9? Any comments, issues? I got it on a standard license to test it. I see an update on clients is required (at least on some of them).
So far, so good. Updated around 600 clients, but have 6 or 7 left that are being stubborn - probably will be fine on the next restart. The âCheck for Updatesâ button in the Administration panel is showing an âError communicating with serverâ error, but that started doing that early this morning under v.5.5.8 - likely due to this new update being rolled out. Definitely something on SHâs end, and does not affect the local server or clients.
Same problem here and it also causes simple setup to fail
My clients finished updating about 30 minutes after my post, so all good here. Iâve utilized several sessions earlier today after the upgrade (a handful simultaneously) with no issues. Hopefully none going forward.
I updated from 5.5.8 running on a Digital Ocean droplet. The clients all updated without issue. It went better than the 5.5.8 update.
Every time I update now my 4k monitor has problems with SimpleHelp.
[EDIT] - To fix display issue on 4k screen after update:
1.Right click and choose Properties on the shortcut in:
\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\SimpleHelp Technician
2. Click Compatibility Tab
3. Click Change High DPI Settings button at bottom of form
4. Click checkbox for "High DPI scaling override
5. Choose âSystem Enhancedâ from the drop down under checkbox
6. Click OK and should display correctly
looks like 5.5.9 has been removed?
From downloads page it is still downloading 5.5.8. But if you run the script for upgrade (at least on linux) it does install the 5.5.9.
since 5.5.8 I obviously update asap as soon as thereâs a new notification, when I went to download the executable it still said that the latest version was 5.5.8 but the executable was for 5.5.9. If you need to remote in into a client before it updates it is painful to connect. It just doesnât work until the client shows updated. I wish the âconnectingâ page would be a little more informative and tell me what was going on, or if clients are being updated to show whatâs the status, I know itâs a big ask and they have other priorities, but it never hurts to ask. Other than whatever has been announced with this release I didnât notice anything else, either good or bad.
Everything works fine for me but the Linux launchers in Pop!_OS disappear when the client updates. Looks like the files arenât set as executable so I did the following and everything came back.
sudo chmod +x â/home/rgravel/.JWrapper/JWrapper-SimpleHelp Technician/SimpleHelp TechnicianLinLauncher64â
sudo chmod +x /opt/JWrapper-Remote Access/Remote AccessLinLauncher64
Made me redo the 2FA on first login.
Terminals will not load for me for macos or linux in 5.5.9. So ÂŻ_(ă)_/ÂŻ
Iâm also having issues loading the bash console.
Sounds like 5.9.10 will drop tomorrow with a fix. So SH is aware of the issue.
I find everything is now super slow. So frustrating, I think I may end up ditching this product and roll my own Rust desk server instead. Paying for this isnât worth it when they keep messing up things in every update.
Ever since I upgraded to 5.5.9 am having issues loading a working bash or any Linux console in all agents.
Confirmed here as wellâŚBlack Screen at any linux shell
Confirm same issue with linux terminal.
Yes - I have same issue with linux terminal. Hoping someone has a fix
