I recently upgraded my netgear router to mikrotik.
With the netgear I port forwarded 8008 for both TCP and UDP and everything worked.
I moved the built-in port 80 web gui from mikrotik to port 8080.
I also forwarded port 8008 for TCP and UDP to my simple-help server, the remote sessions works, but the simple-help welcome page doesn’t load from outside my home network…not sure what other port forwarding setting I need…I tried forwarding TCP traffic from port 80 to my simple-help server but no luck.
What does it do when you try and access the simplehelp welcome page from outside your network? I assume you’re using something like http://support.xxxx.com:8008 ?
Thanks for your inquiry, it just says page cannot be displayed. If i try opening my server ip from inside my network the welcome page works fine. Not sure at this point if it’s the mikrotik or win firewall?
i have about 250 RBs deployed across my network. one thing i have found is when you change a NAT rule you have to drop all connections
/ip firewall connection {remove [find]}
also make sure your firewall rules are sorted by order… when you run out of options i suggest an any any rule for an external IP you’re testing from at rule number 0
Matt, thanks. Didn’t know about dropping all traffic when changing a rule. I have the two ports for simple-help that I activate and deactivate as needed, to keep things as secure as they can be, when I turn them off and on I don’t drop any traffic, they work seamlessly.
Will run some tests on rule 0, can’t remember if I already did or not.
At one point I thought…I bet I can’t see the page because I am trying to access it from within my network…turned off wifi on phone, tried to browse to page and voila’ it works!
@Rob_Nicholson wholeheartedly agree, they just work. Not necessarily intuitive and documentation could be improved but product is just solid and versatile. As my clients burn through their routers I am replacing with mikrotik.
Can’t always make things simple in life. There are tools whereby you have to invest the time. But yes, the documentation could be better. What’s missing is a introductory tutorial or reference manual that explains the principles. Once you’ve got your head around how it all fits together, the reference makes sense. Thank goodness for YouTube tutorials.
