SimpleSetup Migration
Is there a way to migrate the SimpleSetp software/management to another computer without setting it up again. The computer that’s hosting the software keeps crashing. The server is located at Digital Ocean. I searched but couldn’t find any information. I did open up a support ticket but haven’t heard anything back yet
Can’t they migrate your instance to a functional server and keep the IP, settings etc?
Migrating SimpleHelp is relatively simple ISTR. From memory, all you have to do is install SH and restore the configuration folder?
Actually I was referring to the SimpleSetup software provide by SimpleHelp…
Here’s the response from tech support:
There’re no additional steps:
  • Back up your server configuration
  • Set up SSH between the new machine and the server host
  • Install SimpleSetup on the new machine
  • Configure the SSH password etc
  • SimpleSetup will detect the existing server and not install over it
    • If there’s been a new release, it will let you update the server as normal
The server is working good and I didn’t want to overwrite it. I hope this helps someone on the forum,.
