Despite having a valid cert based on what the admin portion of simple help’s console says, the server seams to be presenting a self-signed certificate.
TLS Certificate
Common Name = localhost
Issuer = localhost
Serial Number = 1F12FC76
SHA1 Thumbprint = 55A8E0EB931CE624E81340403997813942CC93B4
Key Length = 2048
Signature algorithm = SHA256-RSA
Secure Renegotiation:
TLS Certificate has not been revoked
| OCSP Staple: | Not Enabled |
| OCSP Origin: | Not Enabled |
| CRL Status: | Not Enabled |
TLS Certificate expiration
The certificate expires March 7, 2029 (2862 days from today)
Certificate does not match name help.martusgroup.com
Subject localhost
Valid from 29/Apr/2019 to 07/Mar/2029
Issuer localhost
TLS Certificate is not trusted
The certificate is not signed by a trusted authority (checking against Mozilla’s root store). If you bought the certificate from a trusted authority, you probably just need to install one or more Intermediate certificates. Contact your certificate provider for assistance doing this for your server platform.
