Toolbox for Teams
What version of teams do you have? What version per user ?
You can have a different versions per user??? Wanna go crazy this is how you go crazy.
Thankfully there is this guy: https://github.com/uclobby/Get-TeamsVersion
https://uclobby.com/2018/09/04/teams-check-client-version-using-powershell/
He saved my day. Unfortunately simplehelp doesn’t like the dashes he used.
So here it is again with the dashes fixed:
.DESCRIPTION
	This script returns the installed MS Teams Version for each user profile.
.NOTES
  Version      	   		: 1.1
  Author    			: David Paulino
  Info                  : https://uclobby.com/2018/08/23/teams-check-client-version-using-powershell
# Funcion to get the Architecture from .exe file
# Based on PowerShell script Get-ExecutableType.ps1 by David Wyatt, please check the complete script in:
# Identify 16-bit, 32-bit and 64-bit executables with PowerShell
# https://gallery.technet.microsoft.com/scriptcenter/Identify-16-bit-32-bit-and-522eae75
function GetArch([string]$sFilePath)
try
        $stream = New-Object System.IO.FileStream(
        $sFilePath,
        [System.IO.FileMode]::Open,
        [System.IO.FileAccess]::Read,
        [System.IO.FileShare]::Read )
        $exeType = 'Unknown'
        $bytes = New-Object byte[](4)
        if ($stream.Seek(0x3C, [System.IO.SeekOrigin]::Begin) -eq 0x3C -and $stream.Read($bytes, 0, 4) -eq 4)
            if (-not [System.BitConverter]::IsLittleEndian) { [Array]::Reverse($bytes, 0, 4) }
            $peHeaderOffset = [System.BitConverter]::ToUInt32($bytes, 0)
            if ($stream.Length -ge $peHeaderOffset + 6 -and
                $stream.Seek($peHeaderOffset, [System.IO.SeekOrigin]::Begin) -eq $peHeaderOffset -and
                $stream.Read($bytes, 0, 4) -eq 4 -and
                $bytes[0] -eq 0x50 -and $bytes[1] -eq 0x45 -and $bytes[2] -eq 0 -and $bytes[3] -eq 0)
                if ($stream.Read($bytes, 0, 2) -eq 2)
                    if (-not [System.BitConverter]::IsLittleEndian) { [Array]::Reverse($bytes, 0, 2) }
                    $machineType = [System.BitConverter]::ToUInt16($bytes, 0)
                    switch ($machineType)
                        0x014C { $exeType = 'x86' }
                        0x8664 { $exeType = 'x64' }
        return $exeType
    catch
        return "Unknown"
    finally
        if ($null -ne $stream) { $stream.Dispose() }
$Profiles = (Get-childItem 'HKLM:\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList'  | % {Get-ItemProperty $_.pspath } | ?{$_.fullprofile -eq 1} )
foreach($Profile in $Profiles){
    $ProfilePath = $Profile.ProfileImagePath
    $TeamsSettings = $ProfilePath + "\AppData\Roaming\Microsoft\Teams\settings.json"
    if(Test-Path $TeamsSettings -ErrorAction SilentlyContinue) {
        $profileSID = New-Object System.Security.Principal.SecurityIdentifier($Profile.PSChildName)
        $ProfileName = $profileSID.Translate( [System.Security.Principal.NTAccount]).Value
        $Setting = Get-Content $TeamsSettings -ErrorAction Continue | ConvertFrom-Json | Select Version
        $TeamsApp = $ProfilePath + "\AppData\Local\Microsoft\Teams\current\Teams.exe"
        $TeamsArch = GetArch $TeamsApp
        $InstallDate = Get-Content $ProfilePath"\AppData\Roaming\Microsoft\Teams\installTime.txt"
        $TeamsVersion = New-Object -TypeName PSObject
        $TeamsVersion | Add-Member -MemberType NoteProperty -Name Profile -Value $ProfileName
        $TeamsVersion | Add-Member -MemberType NoteProperty -Name ProfilePath -Value $ProfilePath
        $TeamsVersion | Add-Member -MemberType NoteProperty -Name Version -Value $Setting.Version
        $TeamsVersion | Add-Member -MemberType NoteProperty -Name Arch -Value $TeamsArch
        $TeamsVersion | Add-Member -MemberType NoteProperty -Name InstallDate -Value $InstallDate
        Write-Output $TeamsVersion
