I upgraded my server to 5.4.1. Upgrade went fine without any problems.
However, when I connect to a remote host, select File Transfer Mode and go back to the remote session , I cannot control the desktop anymore. I had to disconnect and reconnect in order to access it again. I already rebooted the host but problem persists, Anybody experiencing the same issue?
Just tested this and found the same. Started in remote view, swapped to file transfer and back, then no control of the system until reconnecting. The mouse would appear to react to fields. The Windows 10 search bar would show a text input cursor but would not register any mouse clicks. Tried it a couple of times and it looked like the mouse was stuck over an icon at least once. Did the same test but had already clicked in the search bar and there was no keyboard input either. Reconnecting with the cogwheel in the same session makes it work again. Come to think of it, I have had to reconnect several other times for an unknown reason when starting the remote control that had no screen.
Debian 11 server / Fedora 36 Technician / Windows 10 clients / SimpleHelp 5.4.1
If your clients are still on 5.3.7 then it won’t connect.
Did you try to force update the clients. I normally go through the list of all my clients and force the update by enabling ‘Queued Actions - Auto Restart’
