SimpleHelp Community
Warning triangle
#1
Does anyone know what this triangle symbol is next to my PC (AH-SFF) in remote access? It wasn’t there earlier, but it is now, after a reboot.
Anthony
#2
Hover over it. It should tell you. Should also show in the information section. Will be text with a yellow background. The service may need to be re-installed or restarted.
#3
I have this triangle next to a computer as well. I can’t remote into the computer. Message pops up when trying to initiate a session that the computer is updating. Any updated information on the fix for this?
#4
Under the Info section it will show you the reason.
In my case it said download was corrupt.
Click on the Retry button and it fixed itself.
#5
Greetings,
Not meaning to necropost, but I have a similar but different issue.
Similar in the fact that I have a linux box that keeps getting the Warning Triangle, but different in the fact that the mouseover doesn’t bring up any information, and there is a yellow line on the Information tab, but it is very thin with no text in it. (I have now attached an image showing what I am seeing.)20230109_WarningTriangle_issue
When I connect to the box, I can get mouse control, but nothing I type on the keyboard is sent to the remote machine. I can access in File Transfer mode without issue.
Any thoughts? Thanks in advance for your assistance.
