Anyone else having general performance issues and general freezes with 5.2.3? Upgraded at the weekend and ever since I keep having to terminate and reconnect. Or close the session and restart.
Also, file transfer speeds are very slow. I’ve given up transferring using Simple-Help and I’m sharing from OneDrive - which then downloads very fast on the client so it’s not the internet link.
Re the slow file transfer speed - it’s very variable and might be distinctly worse when using the direct connections. Direct UDP always bad, Direct TCP bad right now but TCP appears to be consistently okay.
I’m pretty sure I’ve always used Direct UDP in the past…
I believed that the Direct TCP and UDP options, don’t go via the server but direct between the two clients. Therefore should have a fastest speeds? But I’m not 100% sure I’m right there.
You are correct. When you are using one of the direct options, the server only acts to connect you to the machine. After that the server is no longer in the equation.
I’ve talked with George once or twice over the last few days. I think they are heads down working on this right now. Keep reporting problems and PLEASE send logs with every report as those logs are very important to getting to the bottom of the issues. They will get this sorted.
I see 5.2.4 was just released today, but I don’t see anything that mentions performance fixes or freezing issues for the technician console. Any feedback?
